I just got a new 1 1/2 horse power table saw. When i turn it on it dims my lights when it get turning it seems ok. Is this common with normal home garage power.
This is right on the money, you have to put in a dedicated circuit. It is not good for the motor because it's starving for power and will burn out before its time. If it's in the garage you may want to do a little investigating to see if you have another plug on a different circuit and see whats all on that one.sometimes it happens to be one that hardly anything is on it. One thing you need to do is look at the motor and it will have a tag that states the amps you need.Not knowing that much about electricity - but I think your motor is drawing more amps than what your system is allowing. In other words - the motor when powering up - is drawing the power and taking it away from your light until it reaches full power. I bet money if you turned on another tool at the same time, you would flip the breaker. You need to put the motor on a dedicated outlet. (I guess?)
I'm an ex-HVAC mechanic and currently have a small business doing marine electrical work. I certainly have a lot to learn, but do have a fair understanding of what it takes to get an electric motor running.Tom, You sound like an electrician?
