So my cabinet build project continues with 8 cabinets almost ready to be installed. Just need to attach the doors and drawer fronts. The drawer boxes are already installed into the cabinets.
Concerning the drawer fronts, what is the recommended way for attaching to the drawer box? I'm thinking I can use double sided tape to temporarily hold the fronts in place and in alignment. But at that point is it just a matter of drilling the holes for the handle and let those screws hold it together?
Thanks,
Tom.
I drill 3/16" holes through the front of the drawer body and then I use 1" truss head (or washer head) phillips screws to secure the face to the drawer body. How many? That depends on the size and style of the drawer. Smaller upper drawers get two screws, each about 1"+ from the inner side. Large drawers get 4 screws. Really large drawers, like 30" or wider, will get 6 screws, the extra 2 going in the center. Since I most often make frame and panel faces, the screws go into the rails. Then they also get the pulls. But sometimes people want the pulls along the top rail instead of in the center, so their screws don't amount to anything for holding the face on.
I'm sure others will have different methods.
Thanks,
Tom.
Double sided tape would be alright to get the fronts aliened. Then put a couple screws into the front from inside the drawer. I normally do it by measurements and use staples to hold the front in place until I can put screws in.
Discussion Starter #5
Thank you so much for the replies. Makes sense to screw the boxes and fronts together.
