1 - 19 of 19 Posts
dont know how many cabinet doors you have made... you may try making some for the garage or basement, before tackling kitchen doors. try building a stoage cabinet or something, make them from pine...
your options for frame are basically cope and stick: ogee, round over, square, or amish(slight bevel?). the panels can be ply or solid, raised panel or flat. you can still go other directions but this is a start.
Kind of limited on solid panel options other than flat/raised. You could do reverse raised (looks like flat though), glass or mesh (pierced metal, brass screen, etc)
carpenter
Discussion Starter #8
Very good answer! Thank u
very good
Finding some doors you like?
If you have cabinet supply shops local ,you might stop by and see if they offer literature on the different molding they offer.
Door is a door tI'll you start adding trim.
carpenter
Discussion Starter #14
Look up "cabinet door applied trim"
Thanks everyone
i just made some doors,laminated pine, i’ll post s photo later, starting to move on me a bit, see what happens? Making some flate panels next wiyh pine styles and rails and 1/4” pine ply
You have the option for thicker doors, deeper struck profiles, beaded doors, mitered doors, applied panel mouldings, applied bolection moulding.. etc.
overlay or inset..
Lots of options
Hard to narrow down "different" for someone else.
I'm sure once Sherwood comes up with a "style" he likes the searches will become easier
Personally I like "mission" style doors and furniture, so the searches are easy for me..
carpenter
Discussion Starter #17
Mission is nice!,arch at the top
Smart and Cool
When I embark on a project like this, I use Google and search images. I will then start saving some of those images in a folder. At some point I go through the folder and start looking at the images and see which ones strike a chord with me for the project. Sometimes I will take elements from different items and combine them.
There is a local cabinet company here that posts pics of their work daily on social media, they do really nice work, and are very current design wise, I save most of their images to use later... :)
I can do that
I use books on historical architecture. Overall design and panel design is one facet, proportion is equally important. Some like to design their doors and cabs close to the Golden Triangle. I have seen some classic kitchens where the upper rail on the top cabinets and the lower rail on the lower cabinets are slightly wider so when viewed at eye level they appear proportional, like looking down railroad tracks. Whatever floats your boat, there is no right or wrong.
1 - 19 of 19 Posts
