1 - 11 of 11 Posts
Hobbyist wood-butcher
I don't exactly understand your comment... Are you asking which type to replace with? and what do your abbreviations mean?
Jointer knives are typically not a proprietary design, so you can get them from after market manufacturers and will likely wind up with a higher quality product. Check Infinity Tools, or Holbren. There are others, I just can't think of them at the moment.
I'm guessing he means stainless steel or hardened steel. I've never seen stainless jointer knives, but they may be out there. I usually get mine (Freud 6") off of ebay. Try looking there.
I wouldn't want either, but he probably meant HSS (high speed steel) but stainless would be too soft to hold an edge and hardened steel too brittle. And really hard to sharpen!
Are you sure the knives need replacing? I still have the original knives on my craftsman jointer that I bought in 1972. The 6" knives are not vehicle specific to craftsman. Any 6" knives would work. There are a bunch listed on ebay.
need to replace jointer knives craftsman 6-1/8". would like at least s/s or h/s. thanks. carl.
make yourself a sharping jig and use like 1000 grit or finer to toutch up the edge, be carefull it will still cut skin, just sharpen them in the unit , they make sharper's for just that kind of job, now if you take them out , i had a sear's jointer and i tried to get them back in , and it took me a long time and i was never satafied with the install, it may have been just me ? the out feed table doesn't move so the snip may be real bad,the knives have to be just about perfect, i got rid of that piece of iron, never will i have one with out both bed's that move, now this is my opion, so other's love them, but not me good luck try sharpen them
sounds like a lot of good advice so far. I know When I decide to finally replace/upgrade my jointer knives, I will seriously look into the spiral Helix blade set at holbrum. I was fortunate to see some in action, and you get almost no marks on the wood from the milling, or at least NONE that I could see.
http://www.holbren.com/spiral-cutterhead/
Reactions: raskgle
I have the grizzly jointer 6" with the spiral cutting head on it. I have not touched it since I installed it. All the separate blades are still in original position, and are doing great. it has been three years since I installed. There are no marks what so ever on the wood like the straight blades leave. I highly recommend a spiral cutting head.
Reactions: thegrgyle
1 - 11 of 11 Posts
