1 - 2 of 2 Posts
I just got a new 10" JET jointer/planer and went to set up the blades. I found that even after setting the two ends even with the outfeed table the blade seems higher in the center of the table. I'm somewhat inexperienced with a jointer and wondered if that is a normal occurence and what I need to do. It did seem the same with both blades. I would appreciate any thoughts or advice.
Try this technique for setting the blades
http://www.woodworkingtalk.com/f2/honing-jointer-blades-how-10066/
It's pretty simple and will tell you right off if the blades are the same height at the ends. Unless your table has a hollow in the center across the width, or the blades are convex both of which are very unlikely, it's a matter of the set up. This will show you how I do it. :thumbsup: bill
1 - 2 of 2 Posts
