Hey Guys,
I'm having an issue with ridges forming along my joinery lines after I have completed a glued up table top. My boards are square edged and glued up flat with no filling. These ridges form between a month or 2 months after I have completely finished the project. So I end with a super flat and smooth surface complete with my finish, only to find that after a couple of months these ridges form.
I use Titebond III and Arm-r-Seal. These small ridges seem to be my clear coat finish, because I can go back and knock them down (very carefully) with a chisel. I'm guessing this is the wood acclimating to the area (my garage has a different humidity level than the table's final usage spot). Is this something people have seen before? And are there tips or things I can do earlier in the process to help eliminate this?
Thanks so much for the help and let me know what other details I need to provide. The pictures below are of a walnut table top with Arm-R-Seal Satin finish and a maple table top with Arm-R-Seal High Performance water base. I had these issues with both and with a few other tables (I mostly use oil based Arm-R-Seal).
The pictures attached were taken right after the projects were completed, so the ridges are not present. I tried to take some pictures of them now, with their ridges, but you couldn't see that small of a feature in a picture.
Thanks for any help!
