Hello all,
I'm not much of a jig person partially because of laziness and partially because I can usually make do without. However, I'd like to make some cuts that are a bit sketchy and would like to make it more safe. I've made these cuts in the past and it turned out alright, but I want to be safer. What I'm working on are Knights for a chess set.
The first picture below is the finished version of a knight that I've done in the past, the second picture is that same piece from the back, the third picture is the piece that I have ready to cut with some red lines added so that you can see roughly where I'd like to make the cuts, and the final picture is a sketch of the jig idea described below (my bandsaw blade isn't that big haha).
The way that I made these cuts in the past was by laying the piece on its side in the groove of a flat board and then held the piece in place while making the cut on the bandsaw. My idea for a jig would be to screw the piece to a small board (I used a screw chuck to turn the piece) and attach that board perpendicularly to another board (with the ball resting on that board). This seems like a decent enough plan to me but I figured if I'm going to make a jig, I should consult folks that are more accustomed to making jigs.
