This isn't a woodworking tool, but I thought I'd throw it up here anyway, if nobody minds. PM me if you're interested.
$1000 or best offer. Pick up locally only, I can not deliver this to you.
This is a 3-phase power bandsaw for use in serious metal working. The Vertical Self-Feed system provides for safe cutting to a maximum height of 14 1/2 inches with a throat of 8 1/2 inches. Great for aluminum and steel tubing as well as sheet metal goods. Also great for repetitive cuts where setup time can be minimized.
This 14" 3 Phase Vertical Self-Feed band saw is designed for multiple uses cutting both ferrous and nonferrous metals.
Jet VSF-14-3 Vertical Self Feed Band Saw Features:
Welded frame and base of heavy gauge steel
Swivel vise for mitering
Heavy-duty cast-iron table
Four blade speeds of 70, 140, 280, and 580 SFPM
Hydraulic feed control
Guide rollers accept blade sizes of 1/8", 1/4", 3/8", 1/2", 5/8", 3/4", and 1"
Jet 414487 Specifications:
Part Number: 414487
Motor: 1HP, 230/460, 3Ph, Prewired 230V
Cutting Capacity Height (in.): 14-1/2
Blade Size (in.): 1/8 -- 1
Blade Speeds (SFPM): 70, 140, 280, 580
Throat Depth (in.): 8-1/2
Blade Length (in.): 120
Blade Width (Min-Max/ in.): 14
Table Size (in.): 30-1/2 x 18-1/2
Table Height at 90 Degrees (in.): 30
Overall Dimensions: 40 x 30-1/2 x 69
Height: 72 inch
Width: 32.5 inch
Length: 45 inch
Part Number: 414487
Height: 72 inch
Width: 32.5 inch
Length: 45 inch
