Hello,
It's been 20 years since I have done any reasonably serious woodworking. It is time to get started on some projects around the house. I need a real TS to replace my nearly useless sears contractor saw. I have decided a 30" hybrid, 110v, would be sufficient for my needs. I would like the option of a mobile base. After much online research, a stop at my local Western Tool Supply (who tried to ram a Delta down my throat), and reading much of this forum, I have my choices narrowed down to the Jet Proshop or the Steel City hybrid. The Steel City is about $100 more then the Jet
Amazon.com: JET 708482 JPS-10 10-Inch Left Tilt 1-3/4Horsepower ProShop Saw Cast Iron Extension Wings, 115/230 Volt 1 Phase: Home Improvement
Buy LT Cabinet Saw 1.75 HP w/30" Industrial Fence, Steel City 10? Cabinet Saw,
I have not been able to see either of these saws locally, so my questions are:
Is one sig easier to set up and get into alignment?
Is one fence better than another (smoother, maintain alignment better, adjustable to maintain the fence face square to the table)
Will one maintain alignment better than another over time? IE arbor remain square to the miter slot, 90 and 45 stops maintain their setting, etc)
Any difference in vibration between the two?
Can the SC be set up with a mobil base?
To add a little confusion: I have seen a riving knife for the first time and it looks like a safety feature I would actually use. I have never liked splitters in the past and would probably not use one now.
The next model up Steel City is just within my budget (a big strech at $500 more) has a riving knife The stronger 220v motor would also be quite nice:
Steel City 35905 10-Inch Left-Tilt Cabinet Saw with 30Inch Industrial T-Square Fence and Riving Knife, 3 HP, 230-Volt, Single Phase - ToolKing.com
Is this bigger SC really worth the extra money (ie a totally different saw that is head and shoulders above the cheeper ones, no comparision between the two) or just a more powerfull version of the 110v model? Is this Riving knife a good setup? I have seen other saws with a split knife. Is one better than another? Are there any other saws at the $1300 point that I should consider. I can't strech to $1600 for a unisaw. I'm not very interested in hunting for a used saw (my contractor saw was used and I wasted my money trying to go cheep). Also, I don't think I can consider Grizzly. I had a contractor Griz 25 years ago and it was such junk I can't bear to buy another Griz, no matter how much bang for the buck.
Thanks for any input,
Tom
Tom
