The reason the more expensive table saws offer more is because the table saw is usually the hub of your shop. If you get a small table saw with sheet metal top, it will probably not be able to handle large pieces of plywood. You can get around not having a good table saw by using other tools. You cant get around a cheap table saw though. Other than the dangers of a cheap saw, it is also often not repeatable. For example, the fence may move when bumped. The lesser motor will probably stall and in the end, you will probably quit using it. For me and lots of others out there, everything starts with the table saw.
My table saw is 5' in from my roll up door. I can slide a sheet of plywood onto the table saw from my van. My outfeed table is on wheels and if the ply is cut, it ends up on the outfeed table. If the ply is not to be cut, it still slides on top of the table saw and onto the out feed table. The outfeed table has 4 swivel wheels and can go anywhere.
Actually, if you are putting together your shop, just everything should be on swivel wheels.
