1 - 10 of 10 Posts
Hi,
I only have room for a portable table saw (I lack a garage or any other place for a permanent table saw). Is using a portable table saw simply a non-starter for building furniture? What would be the most obvious flaw that would be insurmountable given enough care in setting it up and in using it?
Thanks,
Duncan
Hi,
Thanks,
Duncan
WELCOME TO THE FORUM
Not really a flaw, but having the capacity of longer rails/fence assembly. If you're cutting sheet goods having a surround table/outfeed table would be beneficial, and that could be portable. The saw may not be as powerful as some, but having the correct blade helps.
Banned
Welcome,
I'd have to say not a lost cause because people built furniture without power tools. It will be more difficult and if your not careful it could be less accurate because of a smaller table and not as good of a fence. Just get hlp for the larger pieces and make sure the fence is properly aligned.
NO! You just have to take greater care and not to engage in projects where the wood mass would overcome the saw.
I have a friend that builds very nice pieces of furniture with a "portable" Craftsman saw. He used to have a fairly well equiped shop, but in one of his military moves did not have the space for all of the big pieces.
Super Moderator
I agree, it is doable but you will need to devise a way to cut parts which are wider than your fence will allow. I have a larger saw which will cut wide as I need but I can't handle the plywood sheets now days so I use a straight edge and circular saw to get the sheet goods down to manageable sizes.
I had a portable saw to take to the job and it did a great job and had enough power to rip 2X4s, it was a Makita. It is not a cheap saw as you could probably buy a fair contractor saw for what it cost but it was strong and did a good job.
Thumb Nailer
There are plenty of guys (and gals) building furniture with circular saws and cutting guides. So no, it is not a lost cause. Actually, you will find many small shops feature bench top / portable table saws to be space efficient. There are some drawbacks to this idea, mostly mass, table size, and fence related. Sure a $3,000.00 Sawstop cabinet saw would do a great job making parts for that book case... But would it do any better than a $200.00 used Bosch portable table saw? I kind of doubt it... What is FAR more important than the saw is technique...
Banned
If its warm, you could always cut the big stuff outside. ;)
I'm not sure what that has to do with the OP's question.
It would be allot easier to make accurate cuts especially larger ones. Larger sheets on a portable saw can also be more dangerous if care isn't taken to support the wood with either a helper or mechanical device.
Portable vs stationary
A cheapie portable AKA Skill, Craftsman, B and D around $200 or so is a waste of money in my opinion. Too cheap, too light, under powered..I could go on.
A used $200 10 Craftsman cast iron TS would be a big improvement assuming good condition or needs a little TLC.
Next level: $300 -$500 will get you an newer contractor saw with a motor out the back but a real decent saw. Or an older cabinet saw that needs lots of TLC. Or a recon'd portable like this:
Amazon.com: Bosch 4100-09 10-Inch Worksite Table Saw with Gravity-Rise Stand: Home Improvement Next level would be a new portable for $650 or so.
The problem is "room" :eek: A safe sized cast iron table saw on roller stand will take up just about the same room as any portable.
You still need a safe "roomy" space to work especially for ripping.
If you need to store it on a shelf then yes you will want a portable.
News Flash! There's a reason they call them table saws. They often get used as tables! So a saw can be used as a table and when you need to work with it clear it off and saw away. There are swing down rear extensions you can buy or make and support tables as well. So it's really not a matter of "room" if you are clever.
Personally I used a 10" Craftsman series 100 from the '60s for 55 years until I just parted it out and saved the table. There is nothing like cast iron for durability and smoothness. True, the newer portables have great safety guards and nice fences but the aluminum tables will not hold magnets, the latest rage in hold down and feather boards! I have a Bosch 4000 portable and it's the greatest, but it wouldn't be my first choice to make furniture with which was your original question. Confused? :blink:
The newer hybirds take up less space since the motor is underneath rather than out the back and dust collection is much better. I got a steal of a deal on a Craftman closeout reg $1200 saw for $486.00 cash and carry, grunt, grunt. There are deals, you just have to find them.
http://www.woodworkingtalk.com/f12/why-i-needed-new-table-saw-9629/
;) bill
Reactions: dejones and BigJim
Super Moderator
Richard is right, the portable saw can be very dangerous especially cutting long stuff, even with two people. I have seen times when ripping a 4X8 sheet of plywood for bookcases or whatever, the portable saw and stand would slide, twist or tilt and that was with two people so please be very careful.
1 - 10 of 10 Posts
