I am having some difficulty instaling a Rockler router plate i am hoping i can get some opinions.
I am actually build the New Yankee router table. I purchased the router plate from rockler, and after having much difficulty trying to make a template for it, i bought the template from them as well. figured since the top sans the plate was complete, i would test the template on scrap to ensure i had everything correct. I routed it out, and it seemed to me there was too much play around the plate when inserted, but i thought the clamps did not hold properly. I tried again with double-stick tape and i know it held...same results. I tried to shim the distance on the interior of the template with tape, didn't help (or maybe i didn't use enough). I also tried to put tape around the bearing on the bit...same result.
So what can i do to get this template to work? Or is the play around the template acceptable? I'd say it only about 1/16", but it seems like with the tempate, it should be better.
Help!
Help!
