1 - 6 of 6 Posts
I am trying to install Accuride vertical full drawer slides. I've read the other responses but remain confused (my common state of mind.)
I'm worried about the width of the drawer being too wide or too narrow. The part of the slide that screws into the cabinet wall: the holes are drilled in U shaped tabs. Is that design so you can bend them out if the drawer is, maybe, a 1/16" too narrow?
I understand I need 1/2" on each side of the drawer to accomodate the slides but is there any room at all for error?
· Old School
That can be used for some adjustment with a slight bending.
Many of the manufacturers recommend the ½" plus a 1/32" for each side. This would allow for some shimming if necessary.
I normally make the drawer ends 2" smaller than the opening and with the metric size of the baltic birch I use the drawer box ends up 1 1/32" smaller than the opening. Making the box too small can be as big a pain as makeing it too big.
Like Cabinetman said, most side mounted slides require 1/2" plus 1/32", this means the drawers are 1 1/16" less than the opening. This is critical to proper operation. Go to the manufacturers web site and look at the installation instructions.
1 - 6 of 6 Posts
