I had seen the technique of using India Ink to ebonize wood and thought I'd give it a try on a top for an island made of birch plywood. It seemed to work very well, coming out relatively even and free of blotches. I went ahead and did a layer of shellac over it before proceeding to my usual wiping varnish finishing. It wasn't until after I got the shellac on that I noticed a few areas in direct sunlight that showed through to the wood, where I apparently didn't apply the ink thick enough. Do you think it would be salvageable to sand down the single layer of shellac and apply an ebony oil based stain over it to hopefully darken the slightly lighter spots? Or do you think ink over a thin seal coat of shellac would absorb into the wood enough to fix the uneven spots? It's not really noticeable in indoor, artificial light, but only in direct sun that you can see these spots. They aren't super noticeable, and would probably be fine left as is, but knowing it's there and not perfect bothers me. I tried to stretch the coating too thin, as I used more than expected and was running out of it. Should have gotten an extra bottle I guess. You live and learn...
