1 - 20 of 162 Posts
I wood if I could.
I'm knee deep in a building a vertical narrow belt sander that was featured in an issue of Shop Notes magazine a while back. After watching the amazing and brilliant works of Matthias Wandel (Woodgears), then making my cam clamps, I am fired up with inspiration and the allure of making ones own tools.
Here's the project:
Design Machine woodworking Machine tool Advertising
Out of this issue of Shop Notes:
Magazine Technology Machine Games woodworking
What great project doesn't begin with clamp porcupines?
Workbench Table Furniture Tool Toolroom
Table Wood woodworking Toolroom Workbench
Some of these pictures won't be in chronological order. And I won't waste your time with complete play by plays. Just enough to make you wish you were making one of your own. :laughing:
Wood Plywood Hardwood Wood stain
I wood if I could.
Discussion Starter · #2 ·
Bearing block.
Wood Birdhouse Plywood Table Hardwood
Bearing block and upright.
Wood Table Furniture woodworking Plywood
Bearings and shaft. Ooooo... Ahhhhh...
Plywood Wood Hardwood Furniture Wood stain
Wood Plywood Table Furniture
Nice wide chunk of plywood. Should be quite sturdy.
Wood Hand Wood stain Plywood Hardwood
Banned
That's looking great! I'm right there with ya. I wanted a sander and was tired of saving for one. So I was going to build this. But when I told my wife she said her dad bought me one for my birthday/Christmas. Though I haven't seen it yet lol, i'm still waiting. I'm gonna watch this build though, very interesting!
I wood if I could.
Another glue-up.
Wood Lumber
Attached tracking arm stop.
Wood Table Tool Machine Furniture
I felt that the frame of this thing should be reinforced with dowels. The plans don't call for it but I feel it'll be more durable with the added support. This is before I sanded them smooth.
Wood Plywood Hardwood Furniture Table
Start of the tracking arm (hard maple).
Start of the tension arm (Honduran rosewood).
More to come...
I wood if I could.
Discussion Starter · #9 ·
One question: What's the solution for dust collection?
Good question. I haven't even considered that yet. I don't think the plans mention DC at all. I may have to design a shroud of some sort.
I wood if I could.
Discussion Starter · #14 ·
Thanks for tuning in, guys. This project started on a whim. I literally thought to myself "I just made and gave away 16 Christmas gifts. I want to make some kind of cool shop item for myself before getting back to projects for others." Then I grabbed a stack of Shop Notes and others and scanned through and decided on toys project.
I can't upload photos right now but, I got the frame mounted to the base and painted hammered green (like the one in the article). Looking good so far. I also have the tracking arm completed and lacquered. Same for the tension arm. I'm working on the tool rest arm now.
I wood if I could.
Discussion Starter · #16 ·
The base consists of 2 pieces of 3/4" ply glued and screwed together from underneath.
Wood Plywood Hardwood Table Furniture
Wood Plywood Table Tool Furniture
Tracking arm completed (hard maple).
Wood Hardwood Tool accessory Tool
Wood Plywood Tool accessory Table woodworking
Tension arm completed (Brazilian rosewood).
Wood Hardwood
I wood if I could.
Discussion Starter · #17 ·
Sounds like you're progressing quickly. What motor are you planning to use? Did you have to buy one or did you have one laying around?
I have a motor already. It's one that I bought from another member at one of our woodworking club meetings a while back. I paid very little for it. And it happens to be the correct HP rating, exact RPM called for and has happens to already have the correct size pulley. Like it was meant to be.
More shots of the tension arm.
Wood Table Plane Hardwood Wood stain
Wood woodworking Hardwood
Body mounted (glued and lag bolted) to base.
Wood Table Workbench woodworking Furniture
Table Wood Furniture Workbench woodworking
Bearing counter-bores were masked. Other holes were protected by a rolled piece of waxed paper.
Wood Wood stain Hardwood Plywood
I wood if I could.
Discussion Starter · #18 ·
Hammered green. I still want to apply several more coats.
Tool Toolroom Machine Machine tool Workbench
Technology Machine Bandsaw Tool
Tool rest arm (Purple heart). Drilled the washer counter-bores on angled edge.
Tool Machine tool Machine Milling Wood shaper
Completed tool rest arm.
Finger Hand Wood Wood stain
Technology Electronics Gadget Electronic device Material property
I wood if I could.
Discussion Starter · #19 ·
Roller blanks.
Wood Wood stain Table Plywood Furniture
Lower roller band-sawn and drilled for shaft.
Wood Wood stain Hardwood Plywood woodworking
Made a thin wooden washer to protect the decorative cedar end from being damaged/dented during next step.
Circle Wood
Mounted tightly on a bolt.
Box-sealing tape Thread Circle Plywood
Product Thread Wire Auto part Rim
I wood if I could.
Discussion Starter · #20 ·
Then chucked into the drill press and sanded (for quite a while) with strips of sanding cloth to round out and remove flat spots and other anomalies left from band sawing.
Machine Machine tool Milling Tool accessory Wood
This baby is nice a smooth now. And slightly crowned (more crowning may be required but I'll have to wait and see how well the belt tracks before refining any more). But I may still have to true it up more finely once it's mounted to the actual shaft, since the shaft is a more perfect fit than the bolt.
I'm moving right along but there's still a lot more to be done. I'm also still in the process of gathering some of the hardware. Some things, such as the shaft collars and nice aluminum star bolts, were ordered online and are being waited on.
Inn the meantime, there are still more wooden parts to be made.
1 - 20 of 162 Posts
