1 - 6 of 6 Posts
A morse taper is designed to push not pull. I know many of you know this but thought it worth reminding. A morse taper is designed to be pushed against. When drilling holes on the lathe you should get into a habit of holding the chuck when pulling the drill out. Also clear the drill frequently so it doesn't bind in the hole. this and vibration can loosen the chuck and make it come loose in the tailstock.
I was doing photos for a future article this morning and had to let the drill chuck loose while I worked the camera. I'll be I've done this many times and this is the first time I've ever had it come loose on my. Fortunately it only did repairable damage to the workpiece but as you can see ruined my drill.
1 - 6 of 6 Posts
