1 - 10 of 10 Posts
I have s piece of 4/4" maple 4 1/2" square. I want a ring with an old of 4" and an ID of 2 1/2". The outside is easy. How do I do the ID?
Thank you in advance.
Andy
I don't have a chuck that big. If I did, I would worry about hitting bottom in the Chuck with the chisel.
I actually want to th r n a few of these in different sizes. I was hoping to avoid buying a bunch of hole saws.
Glue the workpiece to a scrap-block with a piece of paper in between.
Turn the outside to size, then push a parting tool straight into the middle to cut the core, keep going till you meet the waste block.
Then separate the workpiece from the waste block.
Adillo303 said:
I have s piece of 4/4" maple 4 1/2" square. I want a ring with an old of 4" and an ID of 2 1/2". The outside is easy. How do I do the ID? Thank you in advance. Andy
There are several videos on utube showing how to turn a bangle which should be similar to what you want.
Tom
1 - 10 of 10 Posts
