I need to run some casing through the tablesaw on edge as part of a box build.
This profile:
I need to run it through with the 5/8" side down and the curved side towards the fence to remove the lip on the flat side on the 5/8" corner. The plan is to remove a grove, 1/4" from the width and about 1 3/4" deep. Basically, I'm trying to leaving the small side with a lip 3/8" to 1/2" tall where I can cut a groove for the box bottom, while removing the bulk of the material from the 5/8" dimension above the bottom. The curved side will be the wall of the box with the skinny edge down.. I'm thinking I'm going to need a jig for this as I'm don't want my fingers above the blade and I'm thinking a push stick will cause the piece to rock over.
This profile:
