That would have been my suggestion as well providing the OP was intending to replace the entire wall.actually you don't need 2 separate walls, just separation of the two sides. if you were building new, i'd recommend a 2x6 plate and offset 2x4 studs. since you already have a 2x4 wall, rip a pressure treated 2x4 in half and add half the width to the top and bottom plates. then build the 2nd wall with an offset from the original wall. now the insulation will help, as will 2 layers of drywall
just to clarify... ^^that completely.These are rooms that he rents out. White noise would not help.
I cant verify that it would work, but theoretically, in my mind at least, thats a pretty brilliant idea. Assuming at least that the noise isnt being transferred from the base and top plate. But its an interesting idea for sure.actually you don't need 2 separate walls, just separation of the two sides. if you were building new, i'd recommend a 2x6 plate and offset 2x4 studs. since you already have a 2x4 wall, rip a pressure treated 2x4 in half and add half the width to the top and bottom plates. then build the 2nd wall with an offset from the original wall. now the insulation will help, as will 2 layers of drywall
Not actually a new idea, that's just how sound deadening walls are built or at least one method.I cant verify that it would work, but theoretically, in my mind at least, thats a pretty brilliant idea.
If you are going to open up one side of the original wall, add another thinner wall and insulate, why would you not offset the studs as shown in the illustration of the sound deadening wall?
That was one potential option that crossed my mind. A few different ones crossed my mind and i was seeing if any had any validity or potential in working. Of course now that i think about that again.. i realize i was thinking of the wrong side of a 2x3 or 2x4... If i use the same amount of drywall and paneling that is up now, then i only have about 1.5" to work with. I was thinking about a 2x side of that instead of the x3 or x4.. (this is why i dont do important things on no sleep. I always miss something and its always something thats right in front of my face..)I guess I must have misunderstood because I thought in your previous reply you were talking about adding a 2X3 second wall. Looks like you have a decision only you can make. Good luck in your project.
what i posted is a standard way to reduce noise transmission thru a wall. i did this in my first house i built back in 1982, nothing new. the wall i built was between the laundry room and the master bedroom. as far you attempting it... i suggest adding onto the plate of the existing wall and offset the new studs. if that is beyond your abilities, you should not be doing this, you should look for a contractor to do any construction to your house.I cant verify that it would work, but theoretically, in my mind at least, thats a pretty brilliant idea. Assuming at least that the noise isnt being transferred from the base and top plate. But its an interesting idea for sure.
That being said, no way in hell would i attempt to do that. As you mentioned, interesting idea if it were new construction. But this aint new. And its the main load bearing wall for the center of the house. So i really have no desire to mess around with that structurally. - Tho im glad you shared that. Thats something i probably wouldnt have ever thought of. So it was cool to see.
Have they complained? No. Have i complained (to myself), yes.Has a renter actually complained about noise in the past?
Seems like you are going down the path of time, effort, and cost, will you be able to recover those due to the improvements?
If it were me I would leave it, you aren't renting a 5 star hotel space, it's a nice, clean room, for a fair price I am sure, leave it as it is would be my take.
Yea, thats what i was thinking as well, and trying to articulate (probably poorly). And that even answers my next question about the corner studs. I figured they would have to be there for proper support of the drywall.In leu of that, I believe the best alternative would be what is illustrated below; This is looking straight down.
As I understand it, A 2X2 plate is all there is room for. This means the new added corner studs can only be 2X2 Yes they will be touching the existing corner stud. No way to avoid that I see. ALL the rest of the new added studs are offset and therefore can be 2X4's Using full size 2X4 will retain the rigidity of the new wall surface. Yes the 2X4 studs will sit on both the new and the old plates.
Until one opens up the old wall it is all speculation what one will find he has to deal with.
Well look at that.. I found some old 16d nails. These were probably bought by my dad back in the 90's when he was doing work on the house.Im assuming that if im able to go through with this i should stick to some kind of framing nails? I ask specifically because the only thing i think i have right now are these types of screws left over from when i made the animal room in my basement.
