1 - 20 of 26 Posts
Hello
I want to take apart my kitchen cabinet door frames so that I can remove the inner panel, I only need to take one side loose so I can slide the panel out.
What is the best way to loosen the glue joint? Frames are made of oak and I will be refinishing them, saving the finish is not an issue.
I may have to fire that saw up!!
Here is what I'm up against now, 2 brads in each joint, the heat loosens the glue but I cant pry it apart because of the brads.
In theory,yes. but a 18 gauge brad???? The bit is going to take the path of least resistance....the wood. You'll end up makin' a whole new door I think.:thumbdown:
When I put a brad in the wrong place in my projects, I use a nail punch to push it through just far enough to pull it out with a pair pliers.
Bruce.
That stinks, stupid brads. The only thing I can think of (and this is sloppy) drill a hole like daryl suggested. Just beside the brad, and push the brad head over into the hole were you can get ahold of it with a pair of needle nose pliers.
Don't make too much of a mess that you can't drill a 3/8" hole over the whole area once the brad is out. Take a 3/8" oak plug and glue it in to patch. Kinda sucky idea, but that is all I got. They are on the inside of the door at least.
An endgrain oak plug if you line the grain up with what is there shouldn't look too obvious.
I have to agree with Daren. Drill it out and use a plug. I think anything else would be to obvious. Of course I would weigh the option of how much time and labor you will be putting into the doors verses just making new ones.
another drilling option
Along the lines of drilling a small pilot hole, perhaps you could take a countersinking cutter and remove the pilot drill. Then drill down with the brad going into the hole normally occupied by the pilot drill. Chase it down enough to grab the protruding brad with needle nose pliers to pull it out.
Just a thought, haven't tried it before...
Chuck
Discussion Starter · #16 ·
I'm going to try some of the suggested methods and see how it goes.
I've never had to resort to plan C yet, but I aint afraid to do it. lol
Thank's for the ideas guys
Discussion Starter · #17 ·
Got it!! Darens way worked.
The brads are shot in from the back of the doors. I drilled a 3/16 hole to remove them so I can drill for larger plugs when done.
Thanks a bunch.
I believe I would use
a 3/8" diameter, piloted counterbore without the pilot. That way you have a cavity in the cutter where the brad can enter while you are cutting the wood around it leaving a round hole that will accept a plug.
Ed
1 - 20 of 26 Posts
