This will cut easily, but it will be messy.
I would leave on the protective backing to avoid scratches until after cutting/sanding.
Options I would consider in this order :
a) Jig saw.
b) Circ saw. Thinner blade helps.
c) Table saw. Likely blade is not intended for this material. I would actually use the blade at full height to minimize the heat build up. Not the normal approach for such thin material, but this is "special".
All of these will do the cut. I would plan on sanding the edges afterwards.
The circ saw or table saw blade may partially melt the material so the edges may be rough.
This makes a lot of dust and chips. I would clean up between cuts.
a) Jig saw.
