Good advice Ricko. I had not considered that the poly might do this.Hi I have used that stain and finish before very nice stuff . The stain drys very fast but I would play safe and give it a good 24/48 hours , so the urethane don't pull any stain when applying it
Thanks Cabinetman. The general instructions are not particulalrly helpful. I will use your dry cloth test and wait likely 2 days to be on the safe side as per the other feedback received.Your label should have general instructions. While the stain may feel dry in an hour or so, I would at least give it overnight. If you rub it with a clean dry cloth, no color should come off.
