You can get a collet to hold a 1/2" shaft with a #2 MT.Hello FrankC I should add the fact that the inside of my headstock is #2 Morse taper if that opens up more solutions.
When that arbor is inserted with a draw bolt it will be as secure as anything threaded on your spindle.The first one is very close to what I've been trying to describe Dave. If it had a 1/2 x 20 tpi bolt sticking out of it about an inch and a quarter or inch and a half that would be it. I've got some more search terms now though, Thank You.
FrankC That is the correct outboard side I'm looking for but would like the more stable and secure threaded mounting to the headstock. Thank You
Well, that may be the way for me to go then because the only thing I've found is this:When that arbor is inserted with a draw bolt it will be as secure as anything threaded on your spindle.
