I recently bought the Lee Valley double-ended mandrel http://www.leevalley.com/US/wood/page.aspx?p=32960&cat=1,43072,45939
to set up a slow-speed grinder. It looks like nothing could be easier, but I just can't get it to work. I'm using a 1 hp motor, 1720 rpm. I'd like to post a photo but can't figure out how to resize it to meet site requirements.
The instructions for aligning the mandrel state that "if the drive shaft of the power source turns counter-clockwise, position the RIGHT-hand threaded end of the mandrel on the same end and parallel to the drive shaft." I positioned the right-hand threaded end of the mandrel on the right side because my motor runs counter-clockwise. But after running the motor for a few minutes, the wheel locks up and the mandrel pulley slides to one side even though I tightened the pulley with the set screw. When I switch the mandrel end-to-end I get the same problem, no matter whether I place the wheel on the left hand side or the right hand side.
I'd appreciate any ideas you might have to fix this problem.
Kim
Here are the photos: https://skydrive.live.com/?cid=717E...#cid=717EC8BC45EC3D14&id=717EC8BC45EC3D14!347
Kim
