1 - 9 of 9 Posts
OK, I'm making some bird houses for friends and family to hang this spring. I really like making them but I do wish I had a second pair of hands.
Is there a simple jig or trick for holding the walls in place while I fasten them together. I'm not doing anything fancy, just making a box with a roof and a floor. I don't have a nailer so everything is done the old fashioned way (for now).
I hope this all makes sense, and I'd be willing to bet a dollar to a donut that the answer is so simple I'm going to feel silly.
As usual, Thanks!
Make yourself some "carpenter square" type blocks out of probably 3/4" wood and then use clamps to fasten one wall to one leg and another wall to the other leg.
Remember you from a band saw problem post but never saw your feedback on resolution. What did you do to solve it?
How about "medium width" masking tape? Just tape the sides together into the box form and you're done. I assume that you are using simple butt joints and not miters, so that should work. Experiment with the roof and bottom, but once the four "sides"are together, should be a snap. Good project too, birds are great builders as well! Chief
What kind of joint? Simple Butt Joint? Rabbet?? A Platform made from 2x material with Dado's cut at the appropriate dimensions would allow you to insert the walls for nailing and removal.
I made a jig. Nothing more than 2 pieces of 1x6, about 8" long. Diagonal brace on the inside and built very carefully to get the two sides perpendicular/90 degrees. The work to be joined gets clamped to the outside. Put sides A & B together first. Then sides C & D. Joining them and the whole thing is square.
1 - 9 of 9 Posts
