1 - 12 of 12 Posts
Furniture Table Wood woodworking Machine
Product Furniture Table
Wood Furniture Wood stain Hardwood Table
Made to cover a behemoth old steam radiator in a Victorian home that was getting new flooring. Stain is a custom blend of about 4 colors to match the flooring. Finish is gloss spar varnish. Sorry for the crappy pics guys
Had to do some very delicate scribing to make this unit fit tight against the funhouse-quality bagged out plaster walls. They were so bad I actually made & scribed in a plywood mock-up, then disassembled it & used it for patterns.
Wood Plywood Table Hardwood Wood stain
That's the leg
Wood Roof Plywood Table Hardwood
And that's the top.
I cut within 1/4" of the line with a jigsaw, then clamped the pattern on & routed. Had to run the router backwards to keep the hickory from tearing apart & splitting on the grain.
My phone was dead when I installed it, but I'm glad to say that in the end, it fit like it grew there ;-) I have to go back to make a template for some old crown molding the homeowner wants reproduced, so when I do I'll get an installed pic.
Nice job with the cover you did a great job. I made several of those when I lived in Honesdale, PA. back in the mid seventies. When I made the vanity in my bathroom I had no choice but to build it into the vanity. Sure is better than looking at those old radiators.
GeorgeC said:
Looks very nice.
One question. Would you not want the top of a radiator cover to be open just like the front? Since heat rises I would think a solid top would limit the efficiency of the cover.
It's only 30" wide. The left side is completely open as well. I've never seen a wood cover of this size & style with a vent in the top. If it were 48" or wider I'd have probably put a grill in the top.
sanchez said:
Looks good, that's a lot of scribing!
Nice shop you have there!
Thanks Sanchez. Keeping the front of the case plumb & the top level while not blowing the valve cutout was tricky.
I wish I could say it's my shop! It belongs to my employer, but I have free reign off work hours. It's a cool arrangement.
I wood if I could.
That looks really nice there! I'm sure it's indescribably more awesome than the ugly radiator it conceals. Great job, Sir! Your client must be thrilled.
1 - 12 of 12 Posts
