1 - 6 of 6 Posts
Hi I'm new here. I am starting a chicken coop and need to build some nest boxes but I did not cut out the dividers perfectly. I have four 12/14 squares of wood, but they all are mildly different sizes. It is alot to take of with sandpaper, but I do not know any other way to do it. I do not have a big shop, I just have a circular saw, a jigsaw, and a sander. Is there any way I could get these the same size? I don't have any place to clamp them so that I can hand-plane them. They are four pieces of wood.
Thanks.
p.s. I know some people would use a jointer but I dont have one.
If you want them exactly the same size, this would work.
Take a 2' x 2' piece of 3/4" (1/2 would work) plywood. Drill a few holes in the base plate of your circular saw, and screw it to the plywood, being sure there is at least 16" from the blade to an edge.
Plunge the saw blade thru the plywood. You now have a "table saw"
Clamp a straight edge parallel to the blade (align carefully) at desired cut width.
Rip your pieces to size.
I made one like this, that fit on top of a plastic milk crate, that I used, when I was living on a sailboat, and couldn't quite fit a cabinet saw on board!
Besure to secure the "table saw" before using it! Safety is first.
1 - 6 of 6 Posts
