1 - 11 of 11 Posts
Can anybody id this machine? There is a faded tag on the front from which I've gotten some info. A web search hasn't done me much good.
National Industrial Tools
Model IP-15 (15” Planer)
Product Number 190415
Serial # 40640
It works but the thickness of the result is greater on one edge than the other. I assume there must be a way to adjust that but...
Also, I'm unsure what the knob is on the right. You can push it in and out as if to engage/disengage some function. I've only run it in the "out" position, and am scared to do otherwise.
I guess it is ID'd well enough above but I am looking for help with it. A manual would be amazing!
Thanks, all!
I think the knob on right adjusts the speed of rollers. Mine-delta is only supposed to be shifted while running.
>Dave Paine: Great lead! But I asked and the seller has no manual. :-(
>Joeb41 I ran across this same ad. I talked to them and they sent me a pdf photocopied manual. The print was barely readable and the pictures were worthless. I may ask for a redo on that.
>Mike1950 In the manual referenced above I learned that that knob cuts the infeed and outfeed powered rollers in or out. I'm not clear as to why one would want to change that setting though.
Basically, I am trying to figure out how to get the unit to cut an even thickness from one edge of a board to the other. I also am going to have to figure out how to set and adjust knives, as these look like they need to be sharpened...
Thanks, guys! I appreciate this forum!!
Scotty D
It may be that the knives are installed incorrectly.
I would remove/sharpen/replace them before trying anything else. :smile:
This exact same planer was left behind by the previous owners of my house. I was wondering if you had any luck locating a manual? If so could you please point me in the right direction?
National Industrial Tools​
Model IP-15 (15” Planer)​
Product Number 190415​
Serial # 40640​
Thanks, all!
Hey guys i just picked one of these upas well it appeares its made by transpower and in taiwan i paid 200 bucks for it hope it was worth it ill send u a picture
Serial # 40640​
Thanks, all!
430539
1 - 11 of 11 Posts
