We have an introduction section where you can say a few words about yourself. If you fill out your profile in your "User Control Panel", you can list any hobbies, experience or other facts. You can also list your general geographical location which would be a help in answering some questions.
Since your repair would be to the area of the apron, you could get a good match for coloring. What you likely did was abrade the area too smoothly, which would make stain penetration difficult. You might try sanding with 180x-220x, and fade out the edges of the sanding area so you don't have a sharp sanded line next to a colored area. Sand only with the grain.
If you have a very soft paint brush, maybe only 1" wide with long hair bristles, there is a technique you could try. If you don't have a good brush, pick up a woman's make-up brush. The one she dabs in the colored face war paint (maybe called blush) and whisks it over the skin. It might look like a shaving brush. Very soft bristles. You can snip off the outside rows of bristles until you have a nicely shaped straight brush.
If you have already tried a stain (the one that didn't take), and it's an oil base stain, take the can and stir it well. Have a clean cloth ready, and get some stain on the brush and let it flash dry off for a few minutes. Then lightly whisk over the bare area with the grain. You might try this on a sample first, but if you can get the hang of this, it's really pretty easy.
If you want to try a gel stain, and you have the right color, read the directions, as each brand may differ. But, basically, the way it works is you brush it on (some may have a flash time of a few minutes), and then wipe/brush it off to the intensity to match. The more it's drawn off, the lighter it will get. It would be to your benefit to also try this on a sample. If you have no wood scraps, use cardboard.
