I do. And yes, i have some experience in making the best of a marginal piece of wood. Still learning some of the tricks, but i have had pretty good luck at it.Yes. It's cherry. I assume you have a planer and I assume you know about cutting pieces down as small as you can before trying to flatten and straighten with your planer and jointer. Less waste that way. Particularly when using frame and panel construction, it is pretty easy to straighten and flatten the shorter and narrower components. It looks like the boards you show are pretty flat and straight though. Good find. Congrats.
No, unfortunately the guy that has/had it passed away recently and we are trying to clean up his place.did he mention if it was kiln dried or air dried?
