Craftsman saw?
The tilt gear bevel teeth get gummed up with saw dust. You have to look underneath to see where those gears are, then use a ice pick or small screw driver to clean out between the teeth, usually the small gear. You should just tilt the blade every so often to keep them clean, a lesson I learned the hard way. :thumbdown:
