I recently glued up a walnut, 3/4" thick table top roughly 5' x 32". I used Titebond III and biscuits to join the boards together. I finished it with ArmRSeal on all sides and everything turned out great. I have a metal pedestal base that I will be mounting the table top onto. The metal base has an 11"x11" square plate that has slotted holes to screw the table top to. I wanted to double the wood thickness in the area the 11"x11" plate would attach to on the bottom side of the table. I added a small glued up square of the same thickness of walnut. I glued and screwed this second slab on. So I would have 1.5" total thickness of wood where I was going to screw into. I did this only to give me more material to screw into to connect my metal base. The picture shows exactly what I did (pre ArmRSeal). Also added a picture of the finished product top side.
I'm now really starting to second guess this because the top slab needs to be able to move and adapt to whatever environment it is in. I'm thinking that my second glued up section will restrict the actual table top from being able to move. And my second section is going crossways from the board direction of my actual table top. My question is, do I just wait and see if this thing starts cracking because I didn't allow my top surface to move? Just looking for any opinions on what to expect/what to do. Since I glued everything together, really not sure how to go back from that. Any advice would be greatly appreciated.
Thanks!
Thanks!
