War Damn Eagle! Congrats on the Championship!Bama…Started watching them serious around 2010…Amari Cooper fan..
Not sure where they are going after this year. Bad two yearsWar Damn Eagle! Congrats on the Championship!
Blum is generally more than Grass, I won’t buy KV drawer slides anymore..Blum is worth the cost. I’ve used KV slides, too.
Yesshouldn’t be hard to make upper blind corners..
If I’m reading this right. It’s a U shape and another wall by itself?
This may be a ”one & done” but I have three daughters. The older two are 25 year old twins. I know when I finish this house, her twin will be buying one. The 22 year old wants to flip houses, but doesn’t want to help me or even watch. I’m not financing that!My daughter and son in law did their kitchen. Took them a few months, one cabinet at a time. Daughter even bought paint and sprayed them. I refused to do her cabinets, she tried to tell me how to build them..
There were a few flaws, but she made good money on the sale of the house
Said she would never do it again..
Do you have a budget for tooling?Yes
Slides I use 100% KV MUV slides. I get them at a great price point and they work extremely smooth. I have even redone my system for furniture and have been using them in my dressers. Hinges I use mostly KV, but I like the Blum soft close ff hinges too.Blum is worth the cost. I’ve used KV slides, too.
I stopped using the KV’s because of problems. It could be just a bad lot I got , but scared me away from them..Slides I use 100% KV MUV slides. I get them at a great price point and they work extremely smooth. I have even redone my system for furniture and have been using them in my dressers. Hinges I use mostly KV, but I like the Blum soft close ff hinges too.
I like the comments about starting small. You are putting quite a bit on yourself. Inset doors are the most difficult cabinets to make taking time, patience, and precision. You have to be honest, or learn your ability level and what your shop is capable of producing. Absolutely perfect square and true stock is a must. Wood does not come that way. Do you have the ability to to produce straight and true stock for the face frames and doors? Do you have the setup and skill set to produce perfectly flat doors. Like others have stated I would suggest starting with some shop cabs or perhaps a vanity. For cab boxes I would suggest using prefin maple ply. The nice thing about prefin is you can finish just the face frames before they are applied to the cab for a sharp, clean look. You will need a method to break the sheets down. Wrestling a full sheet on a table saw can be very difficult and if not a good size saw, dangerous. I would do a lot of reading or investigating box construction, There are many ways to do it, each has their pros and cons. You will need to find a way that works for you. I admire you for being willing to take on such a task. Building a kitchen can be overwhelming even for the experienced. I have 50 years experience in shops and just remodeled my kitchen. Just hand sanding of the doors before and during finishing I clocked over 40 hours.
Without some kind of layout it’s hard to help on measurements and design. How you want to deal with a corner, window, etc.
Biggest question is do you want to make a face frame and make a box to fit, or a box and a frame to fit the box.. This usually helps the process..
that looks great!You can do it man. I just did our new kitchen having never built a cabinet before. I have been doing carpentry for quite a while but never anything more detailed than some crown moulding.
So I know the basics of measuring and planning but had to learn A LOT of new tools and processes.
That said I was amazed at the space all that stuff took up. Had it stacked in 2 rooms of the house because the shop was only 16x 20 so 3 or 4 carcasses and it was full.
Painted with BM Command and an airless sprayer. Turned out OK.
I would gladly build 10 more of these kitchens than have to go through that process again. What a sucky mess.
Thinking of trying inset doors on the dog wash station I'm building soon but not sure me and my tools are up to that yet. View attachment 449425 View attachment 449426
I will add that it is far from perfection, a couple doors aren't perfectly flat, and some minor stuff like paint in the groove between door panel and rails and stiles but I saved about 10k compared to my neighbors who just had a custom kitchen done. Theirs is all 1/2 ply but dove tail drawers and some other fluff.
Mine are all .75 ply with nailed together drawers but for 10k I'll be ok.
I’ve bought almost every I need except more clamps, maybe a dado stack. My daughter keeps sending me pictures of frameless cabinets, so I went over the differences (for about the 10th time) and she’s still confused about it. I finally said if she couldn’t tell much difference in inset and frameless, that I’m going with frameless. I think she just doesn’t like the partial overlay style.Do you have a budget for tooling?
To save on space, I would make the frames first, door and drawers.,
