Do any of you make your face frames slightly oversized then flush trim with a router once the frame is mounted to the cabinet? This can prevent a mistake that causes the side wall to show from the front. Or do you just cut to size?
Related question regarding my current project: When you have two cabinets that hang next to each other, do you leave the face frame overhang that edge by a bit (like 1/16 or 1/32) so there are no gaps between the two adjoining face frames when you screw the side walls together? Or do you make the face frame flush to the side wall? I was thinking of leaving a bit of an overhang, but have never hung cabinets.
