Hello, I have some beginner questions that I can't really find solid answers on. I'm attempting to add built-ins on either side of my fireplace. I've attached a picture of the fireplace, as well as a picture I was using as inspiration.
The plan is to buy some base cabinets from one of the home improvement stores, and then build the upper portion from plywood. Regarding the upper portion, when building the carcass, is it necessary to also build a face-frame if I plan to finish with molding, or should the molding go directly on the unfinished edge of the plywood? Plus I was wondering how having 3/4 inch plywood finished with a 1x2 face-frame would look from the inside of the cabinet. Not sure if the "lip" it creates on the inside will look awkward or not. Unfortunately I don't know anyone who has built-ins or where to look in person to find a point of reference.
Another concern is the top; I really want to finish the top edge of the cabinets with crown, but am not sure how high to go with the cabinet, and whether or not to completely frame the top of the fireplace. We do have a TV over the fireplace and I think the cabinet should be at least as high as the TV... which in my case the top edge of the TV is 77" from the floor - and we have 8' ceilings. So if I take the cabinets to the top-ish of the TV, that's probably ~80 inches, and then that leaves me with a little less than a foot and a half to the ceiling, will that look poorly designed? If I take it all the way to the ceiling, and run crown above the TV from cabinet to cabinet will it dwarf the room with the low ceiling?
Finally, will it look awkward or poorly designed if the built-ins are centered on a long wall? That wall is 18' and the fireplace is centered. With the built-ins I would only use ~12' in the center of the wall... Will it look poorly designed if there is the extra 3' on either end at the corner?
Thanks for the help!
