1 - 20 of 37 Posts
Nothing incredible...did one yesterday had a lot better curve..this one is straight..one yesterday my mounting screws snapped off in it and im not about to try catching one with my chisels. So here is my first completed bowl.
Food Cuisine Wood Dish
Wood Auto part
Vehicle door Auto part Floor Bumper Automotive exterior
· Senior Member
Looks good for a first or second bowl. :thumbsup:
FYI, you can also mount to a faceplate by screwing a flat piece of wood to the faceplate, then glue the bowl blank to the faceplate wood with normal Titebond glue and a piece of paper the diameter of the bowl blank.
Glue both sides of the paper, allow the glue to set and you will be surprised how strong this joint is for turning.
After you have finished turning, a sharp whack with a mallet and the paper will split, then all you have to do is to clean off the remaining paper/glue as you finish turning the bottom of the bowl.
Thanks..so if a good whack will knock it free...a bad catch would more than likely do the same?
Just curious,what kind of screw are you using?
Wood screws generallya aren't strong enough, and the taper is problem in and of itself. I use machine screws- hex head so easy on/off, plus they're pretty much the same diameter except at the tip. Haven't had one snap yet & I turn a lot of big stuff.
Dave H
Discussion Starter · #9 ·
Dave H
Yeah it was just whatever cheap wood screws i had..read not to use drywall screws and that wood screws would work...well 2 of the 4 broke off in it..dug one out..that other isnt wanting to come out so i tossed it...
Table
Bums me out..bottom shape was looking good on that one.
So machine screws hold a lot better? may have to go find some
Nice bowls keep at it an practice
1 - 20 of 37 Posts
