Yes...don't worry...be happy.:laughing: Glue the face frame.I pretty sure face frames should be glued to the carcass of a cabinet, bookcase, etc., but I worry about wood movement of the stiles being restricted by being glued in place. Am I worrying about nothing?
Face frames should be firmly attached to the leading edge of a cabinet. It stiffens the cabinet components, and carries the weight and action of the doors. Face frames should not "float".I should have explained a little better so you don't think I'm a complete idiot. I've seen examples were pocket screws, biscuits or brads are used so the faceframe would float. I'd rather glue it to add a little strength and a better look, so I though I'd just ask what others do.
If you use a wood conditioner chances are the place you fill will be a light streak rather than dark. If that happens you can color the streak with a small artist brush and some tinting color or a touch up marker will work. If you want to be sure, you could fill a nail hole on some scrap wood and try the finish.Thanks for all your replies.
The face frame is on, but I have a new problem. The face frame didn't turn out as tight as I would have like it. A slight gap in one corner developed when clamping. The wood is pine and I am going to use a wood conditioner before staining so the finish won't end up blotching like is so common? with pine. Can I use a wood filler the same color as pine, treat with wood conditioner and then stain? Or would a dark streak result? Any other ideas?
I'd rather have a light streak than a dark. Then I could adjust the color as you have said. And yes I guess a test piece would be the smart thing to do.If you use a wood conditioner chances are the place you fill will be a light streak rather than dark. If that happens you can color the streak with a small artist brush and some tinting color or a touch up marker will work. If you want to be sure, you could fill a nail hole on some scrap wood and try the finish.
