This is a luthier tool and I know it’s not for everyone, but I’m thinking that there might be some clever people here who just might find their own use for it.
So that means there's a curve to the top edges or a radius. But it's very slight, with a leg of 12 ft or 18 ft out from the center of that size circle.It's a radius. The braces are also sanded on this radius and that helps to shape the plates for the top and back of the guitar, or uke in this instance.
A 'flat top' guitar typically has a radius of 12' to 18' and the back is usually 25' to 32'. It helps with the sound and also makes the instrument stronger, better able to withstand the string tension.
Yes sir, and it's easy to see when you look at a guitar from the side.So that means there's a curve to the top edges or a radius.
Much in the same way that when you see an empty flat bed trailer you can see it's got a crown to it and it's not really flat. In that way it is better able to handle the stress and load when it's carrying weight.Interesting concept, not being a luthier I don't understand the end result completely but can appreciate the ingenuity.
A flat top acoustic guitar, does not have a flat top, it has a slightly curved top. So, the mating surfaces on all the edges must conform to that curve/radius.Interesting concept, not being a luthier I don't understand the end result completely but can appreciate the ingenuity.
Guitar backs and tops are in the 0.100" to 0.080" range and easily conform to the large radius. I don't know the thickness of uke backs/tops but my assumption is that they also conform to the specified radii.how do you apply flat skin to this contured shape?
