8" shelf boards. They are mitred to 30 deg. angle. I'll be using biscuits, and it'll be on top of a table, so I want it to be as neat as possible. Cut both ends with a power table saw. When I place the edges together, it looks pretty good.
Question is: Do I need to give these edges any further attention before gluing? Very light, fine sanding? Or best leave well enough alone?
I can't quite picture this...
Can you post a picture? Regardless, using biscuits on a 30 degree miter may prove difficult. A full length spline would be better and easier in my opinion. IF you have a good means of securing the boards at that angle, you don't even need a spline. You just don't want the edges to slide as you apply clamping pressure.
You may have to fab up a jig to make the clamping go well....
Old Methane Gas Cloud
you aren't edge joining...you are END joining. Gluing ends doesn't work that great biscuits will help.
That was my thought exactly!
As a suggestion and it will make life a lot easier. Use lap joints and no biscuits / dominos / dowels. An inch "lap" glued and clamped would be as strong as the wood itself.
You could put a slight chamfer (1/16 to 3/32) all the way around the boards of the table top. You may have to do one end of the lap joint with a sanding block.
The result is that the table top will look like tongue and grove. For a casual dining table that would be very acceptable.
Sorry for the terminology mix up. I'm pretty new at this.
"Gluing ends doesn't work that great biscuits will help. "
I'm a little confused about what you're saying here. Biscuits will help, or
won't?
I seems to me that an inset such as a dowel or biscuit would keep things straight and turn out strong, but I have admittedly never done a biscuit before.
The lap joint sounds llike a good idea. I'll take a look at the Festool.
I'll post a picture in a bit to make sure I am not mis-describing it. It's not a dining table, just one part of a crazy concoction to hold books and CDs. So I want it be somewhat solid looking as opposed to fancy-dancy. The wood I have is hickory.
