1 - 15 of 15 Posts
· Old School
We have an introduction section where you can say a few words about yourself. If you fill out your profile in your "User Control Panel", you can list any hobbies, experience or other facts. You can also list your general geographical location which would be a help in answering some questions.
Why use a product like that when there are so many choices for products for interior use?
Depending on the wood you use you might be able to just use a interior oil stain. I'm not sure what is available in the UK. The stain you have in the link is a deck stain and the best way I could describe it is thinned down paint. It would obscure the natural look of the wood. You might locate a picture of the look you want and we could maybe help you get there.
I understand that wood oil or wood stain is better, but the colour range seems to be very limited locally (in Lithuania where I live). I saw at least 10-15 different colours (http://www.asepas.lt/index.php?page=Aliejus medienai&language=EN). I am still wondering how to resolve TVT5078 colour to a more popular range, like RAL system and to try to obtain at least the pigment abroad.
Hi,
Is it good to use this product for interior? Thank you
No it is not .
Health and safety classification
according to EC Directive 99/45/EC
Harmful, Xn Contains: Naphtha, hydro-treated heavy, turpentine, tolylfluanid (0,67 w-%) FLAMMABLE. HARMFUL BY INHALATION. HARMFUL: MAY CAUSE LUNG DAMAGE IF INHALED. MAY CAUSE SENSITIZATION BY SKIN CONTACT. HARMFUL TO AQUATIC ORGANISMS, MAY CAUSE LONG-TERM ADVERSE EFFECTS IN THE AQUATIC ENVIRONMENT. Do not breathe vapour/spray. Use only in well-ventilated areas. Avoid contact with skin. Wear suitable gloves. Do not empty into drains. If swallowed, do not induce vomiting: seek medical advice immediately and show this container or label. Keep out of reach of children. A Material Safety Data Sheet is available on request.A Material Safety Data Sheet is available on request.
Environmental protection and waste disposal
This product must not be poured down drains, into waterways or onto the soil. Any product remaining unused and dried paint waste must be disposed of as hazardous waste. Dry, empty sales packaging can be taken to a metal bank for recycling or to a public landfill site. Risk of self-ignition! Cleaning cloths, sanding dust and overspray containing the product can create fire by self-ignition. Waste like this should be collected and stored e.g. in water before disposal or be dried preferably outdoors.
This stuff just about glows in the dark .
Why have it inside your house ?
I'm having dificulty with the link. If the color is the TVT 5078 on this chart then the pigments you would need would be raw umber and black. http://www.vivacolor.lv/color-cards/tikkurila-valtti-koka-parklajumi/ You could make your own. Stain has a binder such as linseed oil to hold it together and color tints and thinned with a solvent. The color tints are the pigments that a paint store has in their machines they use when they mix a paint color for you. It's just on stains umbers, black, reds and yellows are used mostly.
You could also use the exterior stain you first mentioned but I would go slightly darker and apply the stain and wipe the excess off so it doesn't obscure the wood.
If you are not mixing new cabinets with old ones with another stain then an a exact match isn't that critical. Just measure and record the amount of each pigment you put into the mix for future reference. Be sure you have more than enough stain so you don't have to mix more in the same run. That usually isn't a problem. Usually you end up trying to make a quart and end up with more than a gallon tinkering with the colors. I usually start with no more than a ounce or two and see what pigments it needs. Often you mis-guess and have to throw it out and start over. If you are trying to match some other cabinets you will need to tinker with the color but also put a clear coating on it to see if that changes the color. It's also good when you are matching a color you take the sample and the test piece of wood out in the direct sun to compare them.
1 - 15 of 15 Posts
