1 - 11 of 11 Posts
I'm getting ready to move my Shop Fox collector to a small shed on the shop porch....
Looking for experience on what brand(s) of stop/start remotes are reliable....
It's a 220 volt unit.....
I used a Long Ranger for about 9 years before I dropped the remote once too often onto the concrete....then it started working intermittently. I replaced it with a Shop Fox that came with 2 remotes and was quite a bit cheaper. It broke within a year...the outlet on the main box simply fell apart. Now I use what I consider the blongest lived option. Get a commercial relay, one that's switched on/off with a simple lamp remote. You can get the relay at most industrial suppliers like McMaster, Grainger, MSC, etc. The lamp switch you get at the box store for about $10-$15. Then you need about $10 worth of odds and ends (a box for the relay, etc.) and you have a life time remote. If the worst happens and the lamp switch remotes quits working, you keep a spare on hand, switch it out and you're back in business. You will need a 120V service near the relay for the lamp switch, but is about the biggest drawback to this system.
Old Methane Gas Cloud
I have the Long Ranger made by Penn State, got it from Grizzly. Been using it for years with no problems.
Same here... A great product. (It's Penn State Industries, btw.)
Sometimes mine will lose its programming. (Twice in 10 years or so.) I just follow the instructions on the side of the unit to reprogram the remote to the main unit.
Discussion Starter #7
Ordered one of these today..... Thanx for the input....
I have a Delta 50-760 DC with the PSI remote which I have used for about 4 years and I noticed something strange when I went to unplug the DC from the control unit, the prongs of the plug are melted in the socket. I could not remove the plug even with a screw driver (of course I unplugged the power first). Anyone else experience the same thing?
definitely not a good sign. sounds like the remote control receiver is under rated for the DC's required amperage.
Even so, something caused too much current to go through it to cause damage like that. Maybe the DC needs a going over, but something went wrong.
1 - 11 of 11 Posts
