I prefer a mobile DC unit, over a fixed pipe system
I have two 1100 CFM Jet DCs in a 900 sq ft shop. One services the planers and drum sanders, the other the tablesaws and a jointer. I connect the tool in use at the time, with a quick disconnect type fitting I cobbled up using a 4" PVC coupler and a flared DC fitting. It takes only seconds to swap out the very short flex hose to the DC unit.
If I were to have a fixed pipe system I would center the DC unit on the wall, and have a blast gate on each side, keeping the flex hose to a minimum. There is a difference between chips and dust and an inefficient system will work better on chips unless the inlet is right at the source of dust. Gravity is the most "effective" in large cabinets like the tablesaw since most dust just falls down to the dust port rather than getting into the airstream. It take huge volumes of fast moving air to get all the dust in a table saw cabinet, not capable for a home shop DC unit. A blade shroud is now more common on the newer table saws, a very good thing! :smile2:
Of course, the drum sander is the monster of dust generators in the home shop and a direct flex hose right to the DC is what I use on both the 24" and the 12" baby Grizzly. The thickness plane stands right next to the sanders, so it's easy to swap over when using that machine.
Most folks don't recognize that a DC is a blower, not a sucker. It only sucks because it's trying to blow out in the first place. You then need to make certain your filter is not clogged because it's trying to blow out through the filter. A cannister filter has much more surface area, so it's more efficient in that regard than a bag filter. Anything that gets past the filter is blown into the room, so a clean filter works best to a certain extent. A partially coated bag filter, filters better, but is not as efficient, so it's a trade off.
Dust collection is a science and since it's like electricity, you can't really see it work that well, you just have to experiment a bit to get what works best. Of course you can get a vacuum or air flow measuring device called an anemometer.
https://www.amazon.com/General-Tools-DCFM8906-Digital-Display/dp/B00275F5EM
