Hey,
I'm working on getting my DC up and running-have this unit http://www.grizzly.com/products/2HP...h-Aluminum-Impeller-Polar-Bear-Series/G0548ZP
coming on Friday, weather permitting.
I'm trying to figure out how everything will fit together in terms of ducting and fittings. I am using 6" PVC, and in some cases reducing down to 4" for some machines and in some cases 2.5" (I know everyone recommends trying to stay 6" all the way thru, and I might work on modifying the machines at a later point to do that, but for now I'm working on getting set up).
My question is about how to connect from the 4" either direct to a machine, or in the case where I am reducing down to 2.5" how to connect the flex hose. The guy at Grizzly thought Fernco fittings http://www.fernco.com/plumbing/flexible-couplings might work since they are rubber and flexible and should fit onto the PVC or reducer and let me connect the flex hose.
Is that a good solution or is there another way to do this?
The second question is I am going to introduce a separator before the DC. The lids I've seen you can buy all have 4" ports and everyone recommends keeping that 6". I was going to try to make a simply plywood lid with 6" elbows glued in. Is that the move? Any idea where to get the 6" elbows for that that will connect to flex hose?
Thanks,
Nathan
Thanks,
Nathan
