1 - 17 of 17 Posts
I have a small shop so I work very hard at purchasing tools that can be used for multiple purposes. Years ago I recall seeing an article in a magazine on turning a drill press into a oscillating spindle sander. I don't recall how the mechinism worked, but it made the drill spindle go up and down automatically. Has anyone here done anything like this? I'd love to see pictures if you have. Any input is appreciated.
It's not a matter of biteing the bullet. I have looked at the Ridgid and the price is not my issue. I am trying to conserve the little space I have for really important machines and get double duty out of my equipment. The more machines I buy, the tighter the space gets.
I hear ya'. But if the drill press/ spindle sander is supposed to save space...I don't see it. Once you build what I think you're trying to build it'll take up a lot of space. Now, if in fact you want to change over machines...I've seen an add on to a drill press to do what you want it to do [oscillate] but I haven't seen one of those in quite some time.
Trust me...I'm cramped fer space too!!! 93.5 sq'.
Actually I don't want to build anything too elaborate. All I want to do is build a thin box to accept the spindle and allow 2" or so of vertical travel. And of course some simple device to move the drill spindle up and down. Maybe this is a pipe dream but I'm an engineer, what do you expect?:yes:
· Banned
If you have a small electronic motor, it should be fairly simple to gear it down then add a brace between a handle of the drill press and a peg on a large gear to make it oscillate as the gear turns. You could mount it on top of the press and make some kind of quick disconnect for when you want to use the press normally.
My only hesitation using the drill press is the additional side loading of the bearings - not something they were designed for. Same for trying to do milling on a drill press. JMHO....YMMV.
1 - 17 of 17 Posts
