For you cabinet builders out there, I have a couple of questions about kitchen cabinets...
1) What do you use for drawer stock (sides and ends)? Mine will have an overlay with a false front added after the drawer has been built and installed.
2) What 3/4 inch plywood do you use for the base carcases when the ends won't be exposed and the cabinet is all drawers? I plan to skin the two outside ends (two cabinets screwed together).
Note: The face frames and drawer fronts will be painted. I am building face frames out of poplar. The drawer boxes and drawer bottoms will be sprayed clear.
I am looking for an easier way that is less time consuming. The last batch of drawers I made by gluing up pieces of poplar, planed them down to 5/8 inch, then cut to final size. I sprayed them with Deft. The end result turned out nice (see attached).
The big drawer was made using maple instead of poplar.
Mike
Mike
