I'm building an outdoor platform (section of deck) that has storage inside it. The top (technically floor?) of this deck will have sections that flip open to access the stuff inside. Here's the problem. Actually there are two. It's right up against the house so there's just no room for a traditional hinge to work since that would require space behind the platform for the door to flip into, which there is none because it's about 1 inch from the house.
Fine, I figured some kind of european style hinge would be needed then. Because they allow the door to flip up in much less space. NOw, problem number two, the frame of this platform ends up being 2 1/2 inches thick, since it's essentially a deck and thus built like one. This effectively means the "overlay" on this "cabinet" is 2 1/2 inches.
So the question: is there a hinge that would allow for a face frame overlay of 2 1/2 inches? I keep reading you can get different mounting plates to make your overlay options "unlimited" but I can't seem to find such a plate that has an overlay as large as i need.
Can someone please tell me where (website) to go to get these kinds of hinges. If you could tell me exactly what to get that would be appreciated.
Failing that, the only thing I can think of to do is move the platform away from the house enough to let a normal hinge work. I don't like the idea of a gap there but if no miracle hinge exists I suppose there's no choice.
Thanks for any help
- Carl
Thanks for any help
- Carl
