1 - 3 of 3 Posts
Super Moderator
Retired Craftsman
Welcome to the forum.
This is the only "3 tooth" cutting/carving disc I could find with a quick search.
Edit: To answer your question; "What are the important points between the three-tooth wood cutting and a wood carving features". It can be used for both operations. As in the video, the "cutting" feature provides less than optimal results. However, when used as a "Carving Tool", it is all in the hands of the operator, the project, the carving skills, and the confidence level and experience of the person operating the tool. I have quite a few "cutters" that go on the 4.5" angle grinder and use them often for different reasons. This blade can be used for multiple purposes WITH AN ABUNDANCE OF CAUTION. I would never recommend this tool to a beginner craftsman with limited experience with angle grinders.
Product Wheel Data storage device Dvd Font
I would suggest the round multi-tooth grinders that are much safer and provide much better carving results.
Tire Wheel Automotive tire Product Tread
Assuming you mean that wheel for an angle grinder which looks like it has a chain saw blade on it the more teeth it has the smoother it will cut. All of them cut like a chain saw but the fewer teeth it has the better grip you better have on the angle grinder.
1 - 3 of 3 Posts
