Ï have never had the need for a dial indicator.
Astraight edge is usually sufficient.
A pair of cheap hf feller gauges is sometimes helpful.
ThanksDial indicators provide more accuracy than is needed in woodworking.
gmc
I guess if you're building fences or houses but I want my equipment dialed in as close as possible, especially for the type of work I do.Dial indicators provide more accuracy than is needed in woodworking.
They are also easier to read than a vernier scale.Dial indicators provide more accuracy than is needed in woodworking.
The caftsmen 200 years ago did some beautiful work. I wonder what type of dial indicator they used.I guess if you're building fences or houses but I want my equipment dialed in as close as possible, especially for the type of work I do.
I do not interpret any of the comments above as "begrudging others for their choice in a tool". They are merely stating a fact that dial indicators and calipers provide a degree of accuracy that is not needed in woodworking. I think it is rare that 1/32" (.03) make much difference in a typical project. However, I agree that it is often a matter of convenience. These two instruments are uniquely suited to measuring inside (and outside in the case of calipers) dimensions. One just doesn't need to get too hung up on the accuracy they provide. I also have a General plastic caliper and I find it as accurate as I need and then some.They are also easier to read than a vernier scale.
Some folks get by using a string and a rock, others use a laser level. Sometimes it's about convenience as well as accuracy. Use the tool which you prefer and don't begrudge others for their choice in a tool. Even if it is more accurate.
The best they could get their hands on, I would imagine. Same as we do today.The caftsmen 200 years ago did some beautiful work. I wonder what type of dial indicator they used.
Didnt have Table saws back then. If it wasn't for my table saw. I too would not have any use for a dial indicator.The caftsmen 200 years ago did some beautiful work. I wonder what type of dial indicator they used. George
Ditto - well said!I go with 2-3 thou as a reasonable tolerance for most things. Admittedly I get a little ridiculous about my planer and I don't stop until I'm within .001" across a 20" blade, same thing with my drum sander. It's a 1-2 hour exercise that explains why my blades are dull. I just feel jointers and planers need to be dead on or you will get a multiplication effect of the error since you can't flip boards without going against the grain. Helical machines maybe not so much.
I think if a someone from 200 years ago were standing next to us they would ask, "Why in heck are you doing that by hand when you've got a mortise machine sitting right there?I'm sure the craftsmen of yesteryear would be very envious of us today with our modern equipment. I'll bet they would be thinking that if they had faster and more accurate equipment how much more creative they could have been with al that extra time on their hands.
Other than maybe the wealthy class, I seriously doubt there were many hobby woodworkers.
