1 - 3 of 3 Posts
Need help locating a Delta sanding belt. Item # DPEC000640
Everyone seems to be back ordered and Delta does not even have it in stock. Anyone else have this problem or have a solution?
Thanks,
SandMan
welcome to the forum. most drum sanders use (almost) universal 3" wide type belting that you cut a triangle off the ends and wrap it around the drum, securing on both ends. you can remove the old one, and if it is still good, use it as a pattern for the new belt. is it velcro backed? is there something special about that model sander?
1 - 3 of 3 Posts
