I have a bad back, and am trying to hollow out a hardwood, still alive in the ground maple tree stump, for use as a planter.
So far I've been able to find two techniques: Using a big horizontal-blade axe, or cutting a ****ton of holes with a wide spade bit, and then a lot of chiseling.
The problem is, due to my back, I can't do the axe, or the chiseling in this material.
My current hairbrained scheme is to first make a lot of holes as close to each other as possible with a 1.5" spade bit, and then use a 1.25" Rotary Tool Circular Saw Blade, plus a bit extender, in a normal drill to cut out the little pieces of wood between the hole saw holes 6" down. Or if those blades won't work with a drill's RPMs, just go down a half-inch at a time with my Dremel.
I feel there has to be a better way / more appropriate tools, but I haven't been able to think of them, thus this post :smile:.
